The ACT branch is building a small library of useful equipment that you probably would never buy for yourself. This is available to members to borrow free of charge. Contact the secretary by email if you would like to borrow an item.
Photo Quantity Description
1 Type 2 to type 1 barrel adapter suitable for charging modern vehicles with type 2 AC charging on older type 1 (J1772) AC charging points. Here's one you can try out at Westfield Woden.
  1 OBD2 Bluetooth scanner that is compatible with Android and Apple iOS devices. This can be used for basic battery health testing using Car Scanner or to improve in-trip range estimates with A Better Route Planner.
1 5-pin tester. This gadget can be used to test a 5-pin industrial socket to check via the three LEDs if (a) it's working and (b) whether it's single-phase or three-phase.
Coming Soon KWIK portable EVSE with adaptable tails to suit everything from 10A sockets (1.8 kW) up to 5-pin 3-phase industrial sockets (16.5 kW).
Coming Soon Type 2 to type 2 cable (max. 22 kW; 5 metre length)
Coming Soon Portable EVSE with selectable 8 amp (1.8 kW) or 10 amp (2.4 kW) speed for trickle charging. Includes timer features.
No image yet, but it looks just like an extension cord Coming Soon 10 metre long extension cord with extra thick conductors (10 amp)
